Celkem je zde 520 lidí (1 přihlášený)
Návštěvníků: 519
Celkem: 520
13.09 2020 17:39
Pre-facelift Cars - 04 - 08 plate
1. Confirmation on Lock
[Select]
[46 - Central Conv]
[Coding - 07]
+2048 to your existing coding (example - original code is 0008443 + 2048 = 0010491)
[Do it!]
2. MMI* High Hidden Menu
[Select]
[07 - Control Head]
[Adaption - 10]
Drop-down Menu
[Select - Service Menu]
Change 'New Value'to 1
[Test]
[Save]
Drop-down Menu
[Select - MMI* System Retstart]
Change 'New Value' to 1
[Test]
[Save]
*MMI* will now restart*
[Done, Go Back]
3. Battery Meter
After MMI* restart and Hidden Menu enable - press Radio then hold in Setup + Car for a few seconds (it might take a few times to get timing correct)
[Select] DIAG SETTINGS
[Select] Car Menus Maske
[Select] Battery Level
Scroll to Accept Changes
Press RETURN 3 times
Restart MMI* using Setup + MMI* Control Knob + Upper Left Inner Key - release
4. Visual Parking Aid - if supported
[Select]
[76 - Park Assist]
[Coding - 07]
Change second digit to '2'
Example - Original code is 0001106 ... New code is 0201106
[Do it!]
Restart MMI* and select reverse
5. Passenger Mirror Dip on Reverse - if supported
[Select]
[52 - Door Elec Pass.]
[07 - Coding]
Add +128 to original coding
Example - original code is 0002682 ... New code is 0002810
[Do it!]
Select LHS mirror on control and select reverse - mirror will dip if correct hardware is fitted
6. MMI* High Startup Screen
[Select]
[07 - Control Head]
[07- Coding]
Look for the 3rd digit and change this to your preference as below
xx0xxxx = A6
xx1xxxx = S6
xx3xxxx = RS6
[Do it!]
Now go into:
[10 - Adaption]
Drop-down Menu
[Test]
[Save]
[Done, Go Back]
7. Disable Seatbelt Warning
[Select]
[17 - Instrument Cluster]
[07 - Coding]
Look for the 6th digit and change this to your preference as below
xxxxx0x = No Seatbelt Warning
xxxxx1x = Seatbelt Warning (EU-NCAP)
xxxxx2x = Seatbelt Warning (NAR Old)
xxxxx3x = Seatbelt Warning (NAR New)
xxxxx4x = Seatbelt Warning (EU-NCAP incl. Passenger)
xxxxx5x = Seatbelt warning (NAR Old incl. Passenger)
xxxxx6x = Seatbelt Warning (NAR New incl. Passenger)
[Do it!]
Turn ignition off and on
NB . 2, 3, 5 & 6 are related to North America.
8. Bluetooth Module Voice Control - If your BT module supports this change
[Select]
[77 - Telephone]
[07 - Coding]
Look for the 6th digit in your current coding and change this to your prefered voice language
00x0x00 = Voice Control Off
00x0x10 = German
00x0x20 = English (UK)
00x0x30 = French
00x0x40 = Italian
00x0x50 = Spanish
00x0x60 = Spanish (USA)
00x0x70 = English (USA)
00x0x80 = French (Canada)
00x0x90 = Speaker dependant voice selection
[Do it!]
Now restart your MMI*
[Select]
[07 - Control Head]
[10 - Adaption]
Drop-down Menu
[Test]
[Save]
[Done, Go Back]
9 - Scandanavian DRL (rear tail lights on with front DRL)
[Select]
[09 - Cent Conv]
[Coding - 07]
Change the last digit in the coding string to '2'
Example - 0xxxxx2
[Do It!]
10. Changing radio source by pressing RADIO
[Select]
[07 - Control Head]
[Adaption - 10]
Additional MMI* Options
Add 4 to your existing code (Frequency/Source Change via Function Button Active)
[Test]
[Save]
13.09 2020 17:40
Facelift Cars - '58 plate onwards
1. Enabling Gauge Test/Needle Sweep
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on the second byte in the list.
Check the box for "Gauge Test/Needle Sweep active"
[Do It!]
2. Hidden menu in 3G MMI*
[Select]
[5F - Information Electr.]
[Adaptation - 10]
Choose Channel 6
change value from 0 to 1
[Save]
[Done]
3. Enabling VIM (Video in Motion)
[Select]
[Control Module 5f]
[Advanced ID - 1A]
Make a note of the serial number and decode using MMI* VIMGen
[Security Access - 16]
Enter the code generated above
[Do it!]
[Adaptation - 10]
Choose Channel 48
change value from 0 to 255
[Save]
[Done]
Restart MMI*
4. Enable Battery Meter once #2 has been completed
Hold in CAR + SETUP
car
carextdevicelist
check "Battery"
return
carmenuoperation
set "Battery" to 5
return
Restart MMI*
5. Enable Bluetooth on MMI* 3G
[Select]
[Control Module 5f]
[Adaption - 10]
Channel 06
New Value = 1
Test, Save, Done.
Now go into the Hidden Menu, see 2. Hidden menu in 3G MMI*
Diagnose>Settings>Tel Settings Misc
Change the available options to - [no WLAN/no NAD/BT/HFP] 4/16
Restart MMI* (Hold in SETUP + Centre MMI* Knob + Upper Right Inner Key]
[Select]
[Control Module 5F]
[Adaption - 10]
Channel 17
New Value = 1
Test, Save, Done.
If you have Nav fitted, the microphone will be present, if no Nav is fitted then you need to purchase microphone pack 4L1 (or 4L2) 035 711 G
6. Enable AMI (Audi Music Interface) on MMI* 3G (after fitting the hardware)
[Select]
[Control Module 5F]
[Adaption - 10]
Channel 6
New Value = 1
Go into hidden menu, hold in CAR + SETUP ... WARNING DO NOT CHANGE ANY VALUES YOU DON'T KNOW OR ELSE BAD BAD THINGS MAY HAPPEN
Diagnosis -> Settings -> Audi Music Interface (AMI) set to 7/8
Press RETURN and come out of the hidden menu.
Press MEDIA, Source and test the AMI.
7. Visual Parking Aid - if supported
[Select]
[76 - Park Assist]
[Coding - 07]
[Do it!]
8. Enabling Lap Timer/Boost Guage/Oil Temp
[Select]
[17 - Instruments]
[Coding - 07]
Check the box for "Lap Timer active"
[Do It!]
9. Enable Rear DRL (Scandinavian Lights)
[Select]
[09 - Cent Elec]
[Coding - 07]
Change the 7th digit (ie the last one) to 2
[Do It!]
10. Enable Passenger Mirror Dipping
[Select]
[52 - Passenger Door]
[Coding - 07]
Byte 4, bit 3 - Position memory for reverse gear dipping active
Tick the box
[Do It!]
Test by turning ignition off and then on, select the passenger side on the adjustment switch and select reverse.
[vyřešeno] 1.2tdi 1.4i 1.6 1.6td 1.8 1.8t 1.9tdi 100 2.0fsi 2.0tdi 2.0tfsi 2.2t 2.5tdi 2.7t 2.7tdi 2.8 3.0tdi 3.3tdi 4.2 4.2tdi 4b 4f 80 8e 8l 8p a2 a3 a3 8p a4 a5 a6 a6 4f a7 a8 abs adaptér aditiva afs airbag ak certifikace ak eshop ak garáž ak karta ak kšiltovka ak servis ak svp ak vlajka ak znak alarm allegro allroad alternátor alu kola ami android androidauto antiradar anténa asr audi audiklub audio autobaterie automat automaticka prevodovka autopotahy autorádio b2 b3 b4 b5 b6 b7 b8 baterie bezdrátové bezpečnostní šrouby bioethanol biturbo bixenon blacklist blikající kontrolky bliká žhavení blinkry blow off blow-off ventil bluetooth bmk bns bose bov brake fault brzdová kapalina brzdové světlo brzdy budíky bílý dým c3 c4 c5 c6 c7 cabrio canbus carplay cd changer centrální zamykání changer chcípá chip chiptuning chladič chladící kapalina chladící systém chorus chrom chyba climatronic cng coming home comming home common-rail concert cukání cívka d1s d2 d2r d2s daylight demontáž denní svícení destičky dešťový senzor diagnostika diferenciál displej dobíjení dpf drl dsg dvb-t dvd dveře dx dálkové ovládání e85 ecu eds egr elektrická okna elektrika elektromobil elsa emise epc esp et ethanol facelift filtr filtr pevných částic fis fsi fólie g71 geometrie gps gufera h1 h4 h7 hagusy haldex hallův snímač halogen handsfree headup hid hodiny homelink hučení hydroměnič hydroštel imobilizér insp intercooler ios ipad iphone ipod iso isofix jak na to k-jetronic kabel kamera kapota karburátor kardan karoserie katalyzátor keyless klepání klepání motoru klika klima klimatizace klub klubová karta klínový řemen klíč kola kolísání otáček komfortni jednotka kompresor konektor kontrolka kontrolka airbagu kontrolka brzd kontrolka mazání kontrolka motoru kotouče kouřivost kufr kód rádia kůže lambda lambda sonda lampy leaving home led letní pneu lišty dveří ln2 log loketní opěrka low-range ložiska ložisko lpg manuál manžeta mapy maska maxidot mazání mlhovky mlžení oken mmi mmi 2g mmi 3g montáž motor mp3 mtm multifunkční volant multitronic měchy měrka oleje n75 napínací kladka napínák nastavení nastavení hodin navigace naviplus nefunguje nejede nestartuje netopí netáhne netěsnost nezávislé topení neřadí nouzový režim nádrž náklon světel náprava nárazník návod odblokování odtok odvzdušnění odvětrání klikové skříně oel okno olej olejnička olejová měrka olejová vana ostřikovač osvětlení osvětlení spz otáčkoměr otáčky palivoměr palivová soustava palivové čerpadlo palivový filtr palubní deska palubní pc parkovací brzda parkovací senzory parkovačky pd pdc phatnoise plnění plovák plynový pedál pneu podsvícení podtlak podvozek pojistka pojistky pojištění pomoc prosim popis pojistek posilovač počátek vstřiku pružiny pylový filtr párování klíče přehřívání přepínač světel přestavba převodovka příručka přístrojová deska q5 q7 quattro radar radio ramena redukce regulace turba relé blinkrů relé světel renovace disků repase repro rns rns-d rns-e rozvodový řemen rozvody rs4 rs6 ruční brzda rádiem řízené hodiny rádio s-line s-tronic s2 s3 s4 s6 s8 safe safe kód schéma sd karta sedačky senzor service servis servisní interval servo servo olej servotronic servořízení setrvačník seřízení hodin seřízení světel silentbloky sklo skryté menu snímač teploty spojení spojka sportovní podvozek spotreba spotřeba spotřeba oleje spínací skříňka sraz ssp stahovačka start start-stop startování startér stk studený start stěrače střešní nosič střešní okno subwoofer svetla svody svolávací akce svítivost svíčky světla symboly symphony syčení sání síto sacího koše tachometr tažné zařízení tdi telefon tempomat teploměr teplota motoru teplotní snímač teplý start termostat teče servo olej tfsi tiptronic tlak tlak oleje tlak turba tlumiče topení torsen tpms trippling tt tuning turbo tuzing tv tuner táhlo tónování těsnění těsnění pod hlavou třetí brzdové světlo usb v8 vag vag chyby vačky vcds vdcs ventilakce ventilakcička ventilátor ventilátor chladiče vibrace vif vin vlnovec voda vodní pumpa volant volnoběh vrzání vstřik vstřikovací čerpadlo vstřikovače vstřiky vyhřívání vyhřívání okna vyhřívání sedaček vynechává vypíná vyčištění vzduchový filtr váha vzduchu víko ventilů výfuk výkon výměna vývěva větrák w12 wastegate webasto xcarlink xenon xuda zadní stěrač zadní světla zamrzání zapalování zapojení zatékání zdvihátko ventilu zesilovač zimní pneu zpátečka zpětné zrcátko zrcátka zrcátka-ovládání zrcátka-stmívání zrcátka-vyhřívání zrcátko ztráta oleje zvýšení výkonu základní nastavení zámek dveří zámek kufru zásuvka únik oleje čelní sklo čep černý kouř čerpadlo čeština čidlo oleje čidlo teploty čidlo teploty oleje čištění čištění trysek řazení řemen řemenice řídící jednotka řízení řízení motoru škrtící klapka škube šíbr žhavení žhavící svíčky žárovky
