Celkem je zde 492 lidí (0 přihlášených)
Návštěvníků: 492
Celkem: 492
Registrace: 11.4. 2009
Příspěvků: 75 | Témat: 10
23.11 2015 10:23
Ahojte, bratovi na A6 BMK. 2005, 250t KM blbne ESP*.
Priznaky :
- Pocas jazdy, po nastartovani , prakticky hocikedy sa rozvieti ESP* kontrolka na MaxiDOte info, ze treba kuknut manual. Ta niekedy pochvili zhasne, potom sa zase rozsvieti , proste uplne nahodne.
- ako nahle sa rozsvieti ESP*, tak sa zvysi volnobeh - asi cca 1100 RPM a naplno sa roztoci ventilator motora - neviem aky to ma suvis ale mozno je to nieco, co by mohlo mat suvis.
S diagnostikou vraj moc nepochodil.
Nestretol sa niekto s takymto niecim ? Vdaka, M.
20.12 2015 17:37
Vypis s diagnostiky :
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI 0000AG 0020
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02334 785 00200
VCID: 2541171FEC14DD36C75-8070
2 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 001 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 327.6 Nm
Speed: 0.0 km/h
Voltage: 11.02 V
Voltage: 4.980 V
Temperature: -6.3°C
Temperature: -6.3°C
Temperature: 45.0°C
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 001 - Electrical Fault
Freeze Frame:
RPM: 903 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.68 V
Duty Cycle: 24.9 %
Temperature: 2.7°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0034757
Coding: 0000001
Shop #: WSC 02327 785 00200
VCID: 285F1E2B9B06C05EFC3-807D
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU*
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 40
Mileage: 273635 km
Time Indication: 0
Date: 2015.12.20
Time: 15:17:42
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 34.0°C
T.B. Angle: 0.0°
Address 03: ABS* Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro* H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
VCID: 264310139112D62ECEF-8073
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU* - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 273604 km
Time Indication: 0
Date: 2015.12.13
Time: 11:25:13
Freeze Frame:
Hex Value: 0x4280
Hex Value: 0x4006
Hex Value: 0x1209
Hex Value: 0x00AC
Hex Value: 0x00FF
Address 05: ACC*/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603601918618
Coding: 0000003
Shop #: WSC 08128 234 84746
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H35 0020
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350GH047523270
Coding: 0000018
Shop #: WSC 08135 234 85907
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000032351
Subsystem 3 - Serial number: 0109.07.040000000100010326˙
Subsystem 4 - Serial number: 010326˙
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0100
Revision: 00000022 Serial number: 00000000035890
Coding: 0008214
VCID: DBB5F1E71AD0DBC6211-808E
1 Fault Found:
01314 - Engine Control Module
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 56
Mileage: 273635 km
Time Indication: 0
Date: 2015.12.20
Time: 15:18:00
Neviem, co s tym moze byt
Příspěvků: 5154 | Témat: 33
20.12 2015 18:43
Me to delali taky a svete div se delalo to cidlo teploty g62 sice nevim jakou souvyslost ma s ESP* a proste vymenil jsem cidlo a mam klid
20.12 2015 20:00
wow, no je to urcite najjednoduchsia oprava a vylucenie problemu. Kupime nove cidlo a uvidime ! Dik moc za info, M.
20.12 2015 20:04
Sam sem sem problem ESP* nepravidelne spousteni vetraku a pri startu hnedka otacky naplno do toho obcas chyba rucky atd tak jsem byl smirenej s ABS* ale koupil jsem cidlo a hned vsechno v pohode neveril jsem tomu ale me to pomohlo snad ti to pomuze a budes mit stesti jako ja
20.12 2015 20:10
a na 3 valci mas spatnou zhavicku
20.12 2015 20:30
No presne tak ako pises, uplne tie iste symptomy, este aj ta rucka nekedy pinda Jj, ten zhavic uz je uz nachystany na vymenu. dik za info, zajtra bezime kupovat nove cidlo a uvidime, ako to vystreli, M.
20.12 2015 20:48
Uvidis budu ti drzet palce dej pak vedet
21.12 2015 14:27
update: ESP* problem SNAD vyrieseny Od vymeny ani jedna chyba , typ jazdenia a pocasie je take iste ako vcera, kedy to robilo stale a dnes nic.. Tak dufam, ze to vydrzi ! Este az dik za tip
21.12 2015 14:54
Uvidis ja mam uz klid od vymeny cidla kdo by to rekl ze to dela cidlo na vodu a koukal jsem i na chybu co si mel a mel jsem ty same v prevodovce a tak
[vyřešeno] 1.2tdi 1.4i 1.6 1.6td 1.8 1.8t 1.9tdi 100 2.0fsi 2.0tdi 2.0tfsi 2.2t 2.5tdi 2.7t 2.7tdi 2.8 3.0tdi 3.3tdi 4.2 4.2tdi 4b 4f 80 8e 8l 8p a2 a3 a3 8p a4 a5 a6 a6 4f a7 a8 abs adaptér aditiva afs airbag ak certifikace ak eshop ak garáž ak karta ak kšiltovka ak servis ak svp ak vlajka ak znak alarm allegro allroad alternátor alu kola ami android androidauto antiradar anténa asr audi audiklub audio autobaterie automat automaticka prevodovka autopotahy autorádio b2 b3 b4 b5 b6 b7 b8 baterie bezdrátové bezpečnostní šrouby bioethanol biturbo bixenon blacklist blikající kontrolky bliká žhavení blinkry blow off blow-off ventil bluetooth bmk bns bose bov brake fault brzdová kapalina brzdové světlo brzdy budíky bílý dým c3 c4 c5 c6 c7 cabrio canbus carplay cd changer centrální zamykání changer chcípá chip chiptuning chladič chladící kapalina chladící systém chorus chrom chyba climatronic cng coming home comming home common-rail concert cukání cívka d1s d2 d2r d2s daylight demontáž denní svícení destičky dešťový senzor diagnostika diferenciál displej dobíjení dpf drl dsg dvb-t dvd dveře dx dálkové ovládání e85 ecu eds egr elektrická okna elektrika elektromobil elsa emise epc esp et ethanol facelift filtr filtr pevných částic fis fsi fólie g71 geometrie gps gufera h1 h4 h7 hagusy haldex hallův snímač halogen handsfree headup hid hodiny homelink hučení hydroměnič hydroštel imobilizér insp intercooler ios ipad iphone ipod iso isofix jak na to k-jetronic kabel kamera kapota karburátor kardan karoserie katalyzátor keyless klepání klepání motoru klika klima klimatizace klub klubová karta klínový řemen klíč kola kolísání otáček komfortni jednotka kompresor konektor kontrolka kontrolka airbagu kontrolka brzd kontrolka mazání kontrolka motoru kotouče kouřivost kufr kód rádia kůže lambda lambda sonda lampy leaving home led letní pneu lišty dveří ln2 log loketní opěrka low-range ložiska ložisko lpg manuál manžeta mapy maska maxidot mazání mlhovky mlžení oken mmi mmi 2g mmi 3g montáž motor mp3 mtm multifunkční volant multitronic měchy měrka oleje n75 napínací kladka napínák nastavení nastavení hodin navigace naviplus nefunguje nejede nestartuje netopí netáhne netěsnost nezávislé topení neřadí nouzový režim nádrž náklon světel náprava nárazník návod odblokování odtok odvzdušnění odvětrání klikové skříně oel okno olej olejnička olejová měrka olejová vana ostřikovač osvětlení osvětlení spz otáčkoměr otáčky palivoměr palivová soustava palivové čerpadlo palivový filtr palubní deska palubní pc parkovací brzda parkovací senzory parkovačky pd pdc phatnoise plnění plovák plynový pedál pneu podsvícení podtlak podvozek pojistka pojistky pojištění pomoc prosim popis pojistek posilovač počátek vstřiku pružiny pylový filtr párování klíče přehřívání přepínač světel přestavba převodovka příručka přístrojová deska q5 q7 quattro radar radio ramena redukce regulace turba relé blinkrů relé světel renovace disků repase repro rns rns-d rns-e rozvodový řemen rozvody rs4 rs6 ruční brzda rádiem řízené hodiny rádio s-line s-tronic s2 s3 s4 s6 s8 safe safe kód schéma sd karta sedačky senzor service servis servisní interval servo servo olej servotronic servořízení setrvačník seřízení hodin seřízení světel silentbloky sklo skryté menu snímač teploty spojení spojka sportovní podvozek spotreba spotřeba spotřeba oleje spínací skříňka sraz ssp stahovačka start start-stop startování startér stk studený start stěrače střešní nosič střešní okno subwoofer svetla svody svolávací akce svítivost svíčky světla symboly symphony syčení sání síto sacího koše tachometr tažné zařízení tdi telefon tempomat teploměr teplota motoru teplotní snímač teplý start termostat teče servo olej tfsi tiptronic tlak tlak oleje tlak turba tlumiče topení torsen tpms trippling tt tuning turbo tuzing tv tuner táhlo tónování těsnění těsnění pod hlavou třetí brzdové světlo usb v8 vag vag chyby vačky vcds vdcs ventilakce ventilakcička ventilátor ventilátor chladiče vibrace vif vin vlnovec voda vodní pumpa volant volnoběh vrzání vstřik vstřikovací čerpadlo vstřikovače vstřiky vyhřívání vyhřívání okna vyhřívání sedaček vynechává vypíná vyčištění vzduchový filtr váha vzduchu víko ventilů výfuk výkon výměna vývěva větrák w12 wastegate webasto xcarlink xenon xuda zadní stěrač zadní světla zamrzání zapalování zapojení zatékání zdvihátko ventilu zesilovač zimní pneu zpátečka zpětné zrcátko zrcátka zrcátka-ovládání zrcátka-stmívání zrcátka-vyhřívání zrcátko ztráta oleje zvýšení výkonu základní nastavení zámek dveří zámek kufru zásuvka únik oleje čelní sklo čep černý kouř čerpadlo čeština čidlo oleje čidlo teploty čidlo teploty oleje čištění čištění trysek řazení řemen řemenice řídící jednotka řízení řízení motoru škrtící klapka škube šíbr žhavení žhavící svíčky žárovky
