Celkem je zde 481 lidí (4 přihlášení)
Nejnovější: Michal2314
Uživatelů celkem: 49 241
Návštěvníků: 477
Celkem: 481
Registrace: 2.7. 2019
Příspěvků: 9 | Témat: 2
27.09 2020 10:56
Zdravim přátelé, potřeboval bych nakodovat zavírání kufru dálkou i spínačem ve dveřích řidiče. VCDS MAX mám jen to nemohu nikde najít.
Děkuji za pomoc
Příspěvků: 11500 | Témat: 100
27.09 2020 12:58
A7/S7/RS7 Only: Close the trunk (a.k.a. boot) remotely using the key fob and/or interior trunk switch (and retain the opening feature)
Go to Module 46 (cent convenience), coding, long coding helper
byte 2, bit 2 "Comfort operation: Remote control active" should be checked, so no need to change it, just confirm that it's set.
No Change, Original Coding: Bit 2 checked
Then got to module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click Adaptation, channel
and there are 8 options for "Activation using rear lid. . .". Change the two "number 4" settings to active.
Original Coding:
(1)-Activation using rear lid opening button in remote key - Touch function for opening: not active
(2)-Activation using rear lid opening button in remote key - Tap function for opening: active
(3)-Activation using rear lid opening button in remote key - Touch function for closing: active
(4)-Activation using rear lid opening button in remote key - Tap function for closing: not active
(1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active
(2)-Activation using rear lid remote unlocking switch - Tap function for opening: active
(3)-Activation using rear lid remote unlocking switch - Touch function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active
New Coding:
(4)-Activation using rear lid opening button in remote key - Tap function for closing: active
(4)-Activation using rear lid remote unlocking switch - Tap function for closing: active
Changing the first "number 4" allows closing of the trunk lid with a quick press of the trunk button on the remote control.
Changing the second "number 4" allows closing of the truck lid with a quick pull of the trunk switch (in the driver's side door)
The trunk is still opened as before. It will beep when remote closing.
27.09 2020 13:27
Tomko děkuji; tohle jsem taky našel, ale ten bezp. kód nefunguje a je asi nesmysl, že by dali 12345.
Přesto děkuji
Příspěvků: 1881 | Témat: 45
27.09 2020 13:47
12345 to je jasný že je to je jen jako příklad
taky tam mohli dát xxxxx
27.09 2020 14:53
Nebere ho? Ja bych tomu klidne veril... delal jsem to na nejakem aute, a myslim ze 12345 bylo ok...
27.09 2020 14:55
Zkus 20113
27.09 2020 20:31
Zkusim díky
Registrace: 10.2. 2011
Příspěvků: 239 | Témat: 2
28.09 2020 22:38
Mne zobralo "12345", keď som to kódoval.
Kód "20113" ti pravdepodobne nepôjde. Ten je na 09-Centrálnu el.
Registrace: 24.10. 2014
Příspěvků: 90 | Témat: 12
02.10 2020 19:08
Tomko má pravdu,mě kod 12345 při kodování kufru fungovalo
[vyřešeno] 1.2tdi 1.4i 1.6 1.6td 1.8 1.8t 1.9tdi 100 2.0fsi 2.0tdi 2.0tfsi 2.2t 2.5tdi 2.7t 2.7tdi 2.8 3.0tdi 3.3tdi 4.2 4.2tdi 4b 4f 80 8e 8l 8p a2 a3 a3 8p a4 a5 a6 a6 4f a7 a8 abs adaptér aditiva afs airbag ak certifikace ak eshop ak garáž ak karta ak kšiltovka ak servis ak svp ak vlajka ak znak alarm allegro allroad alternátor alu kola ami android androidauto antiradar anténa asr audi audiklub audio autobaterie automat automaticka prevodovka autopotahy autorádio b2 b3 b4 b5 b6 b7 b8 baterie bezdrátové bezpečnostní šrouby bioethanol biturbo bixenon blacklist blikající kontrolky bliká žhavení blinkry blow off blow-off ventil bluetooth bmk bns bose bov brake fault brzdová kapalina brzdové světlo brzdy budíky bílý dým c3 c4 c5 c6 c7 cabrio canbus carplay cd changer centrální zamykání changer chcípá chip chiptuning chladič chladící kapalina chladící systém chorus chrom chyba climatronic cng coming home comming home common-rail concert cukání cívka d1s d2 d2r d2s daylight demontáž denní svícení destičky dešťový senzor diagnostika diferenciál displej dobíjení dpf drl dsg dvb-t dvd dveře dx dálkové ovládání e85 ecu eds egr elektrická okna elektrika elektromobil elsa emise epc esp et ethanol facelift filtr filtr pevných částic fis fsi fólie g71 geometrie gps gufera h1 h4 h7 hagusy haldex hallův snímač halogen handsfree headup hid hodiny homelink hučení hydroměnič hydroštel imobilizér insp intercooler ios ipad iphone ipod iso isofix jak na to k-jetronic kabel kamera kapota karburátor kardan karoserie katalyzátor keyless klepání klepání motoru klika klima klimatizace klub klubová karta klínový řemen klíč kola kolísání otáček komfortni jednotka kompresor konektor kontrolka kontrolka airbagu kontrolka brzd kontrolka mazání kontrolka motoru kotouče kouřivost kufr kód rádia kůže lambda lambda sonda lampy leaving home led letní pneu lišty dveří ln2 log loketní opěrka low-range ložiska ložisko lpg manuál manžeta mapy maska maxidot mazání mlhovky mlžení oken mmi mmi 2g mmi 3g montáž motor mp3 mtm multifunkční volant multitronic měchy měrka oleje n75 napínací kladka napínák nastavení nastavení hodin navigace naviplus nefunguje nejede nestartuje netopí netáhne netěsnost nezávislé topení neřadí nouzový režim nádrž náklon světel náprava nárazník návod odblokování odtok odvzdušnění odvětrání klikové skříně oel okno olej olejnička olejová měrka olejová vana ostřikovač osvětlení osvětlení spz otáčkoměr otáčky palivoměr palivová soustava palivové čerpadlo palivový filtr palubní deska palubní pc parkovací brzda parkovací senzory parkovačky pd pdc phatnoise plnění plovák plynový pedál pneu podsvícení podtlak podvozek pojistka pojistky pojištění pomoc prosim popis pojistek posilovač počátek vstřiku pružiny pylový filtr párování klíče přehřívání přepínač světel přestavba převodovka příručka přístrojová deska q5 q7 quattro radar radio ramena redukce regulace turba relé blinkrů relé světel renovace disků repase repro rns rns-d rns-e rozvodový řemen rozvody rs4 rs6 ruční brzda rádiem řízené hodiny rádio s-line s-tronic s2 s3 s4 s6 s8 safe safe kód schéma sd karta sedačky senzor service servis servisní interval servo servo olej servotronic servořízení setrvačník seřízení hodin seřízení světel silentbloky sklo skryté menu snímač teploty spojení spojka sportovní podvozek spotreba spotřeba spotřeba oleje spínací skříňka sraz ssp stahovačka start start-stop startování startér stk studený start stěrače střešní nosič střešní okno subwoofer svetla svody svolávací akce svítivost svíčky světla symboly symphony syčení sání síto sacího koše tachometr tažné zařízení tdi telefon tempomat teploměr teplota motoru teplotní snímač teplý start termostat teče servo olej tfsi tiptronic tlak tlak oleje tlak turba tlumiče topení torsen tpms trippling tt tuning turbo tuzing tv tuner táhlo tónování těsnění těsnění pod hlavou třetí brzdové světlo usb v8 vag vag chyby vačky vcds vdcs ventilakce ventilakcička ventilátor ventilátor chladiče vibrace vif vin vlnovec voda vodní pumpa volant volnoběh vrzání vstřik vstřikovací čerpadlo vstřikovače vstřiky vyhřívání vyhřívání okna vyhřívání sedaček vynechává vypíná vyčištění vzduchový filtr váha vzduchu víko ventilů výfuk výkon výměna vývěva větrák w12 wastegate webasto xcarlink xenon xuda zadní stěrač zadní světla zamrzání zapalování zapojení zatékání zdvihátko ventilu zesilovač zimní pneu zpátečka zpětné zrcátko zrcátka zrcátka-ovládání zrcátka-stmívání zrcátka-vyhřívání zrcátko ztráta oleje zvýšení výkonu základní nastavení zámek dveří zámek kufru zásuvka únik oleje čelní sklo čep černý kouř čerpadlo čeština čidlo oleje čidlo teploty čidlo teploty oleje čištění čištění trysek řazení řemen řemenice řídící jednotka řízení řízení motoru škrtící klapka škube šíbr žhavení žhavící svíčky žárovky
