Celkem je zde 121 lidí (5 přihlášených)
Nejnovější: Wejdík
Uživatelů celkem: 48 388
Návštěvníků: 116
Celkem: 121
Žena
Registrace: 30.12. 2022
Příspěvků: 17 | Témat: 4
07.03 2023 13:46
Dokáže mi někdo poradit s hláškou VCDS týkající se záložní baterie :
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W7 907 468 F HW: 8W7 907 468 E
Component: Gateway H42 0123
Revision: 7C000001 Serial number: 0187C786118117
Coding: 03010001000006407F07000000590032DC9A00071C0000000175078E10000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4E93DB3F11D72C3F5B-801A
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20180122084428 00653
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 3806166204
1 Fault Found:
9457921 - Backup Battery
B1916 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 69
Mileage: 203971 km
Date: 2023.02.10
Time: 16:22:15
H-V activ. restriction-Airbag* control module: not active
H-V activ. restriction-Thermal management: not active
H-V activ. restriction-Engine Electronics: not active
H-V activ. restriction-Transformer for electrical drive: not active
H-V activ. restriction-Hybrid Battery Management: not active
H-V activ. restriction-Ctrl. mod. for contactless charging: not active
H-V activ. restriction-High-voltage battery charger: not active
H-V activ. restriction-HV activation prohibited due to accident: not active
H-V activ. restriction-HV activation prohibited due to de-activation: not active
H-V activ. restriction-HV activation prohibited due to blocking: not active
H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1: not active
H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2: not active
Jde mi o to co je to za záložní baterii, kde se dá případně v autě najít a zda je možno vyměnit jednoduše svépomocí? Nejedná se o záložní baterku pro případné SOS volání, kdy při havárii múže dojít k poškození klasické baterie, aby bylo možno vyslat signál SOS?
[vyřešeno] 1.2tdi 1.4i 1.6 1.6td 1.8 1.8t 1.9tdi 100 2.0fsi 2.0tdi 2.0tfsi 2.2t 2.5tdi 2.7t 2.7tdi 2.8 3.0tdi 3.3tdi 4.2 4.2tdi 4b 4f 80 8e 8l 8p a2 a3 a3 8p a4 a5 a6 a6 4f a7 a8 abs aditiva afs airbag ak certifikace ak eshop ak garáž ak karta ak kšiltovka ak servis ak svp ak vlajka ak znak alarm allegro allroad alternátor alu kola ami antiradar anténa asr audi audiklub audio autobaterie automat automaticka prevodovka autopotahy autorádio b2 b3 b4 b5 b6 b7 b8 baterie bezpečnostní šrouby bioethanol biturbo bixenon blacklist blikající kontrolky bliká žhavení blinkry blow off blow-off ventil bluetooth bmk bns bose bov brake fault brzdová kapalina brzdové světlo brzdy budíky bílý dým c3 c4 c5 c6 c7 cabrio canbus cd changer centrální zamykání changer chcípá chip chiptuning chladič chladící kapalina chladící systém chorus chrom chyba climatronic cng coming home comming home common-rail concert cukání cívka d1s d2 d2r d2s daylight demontáž denní svícení destičky dešťový senzor diagnostika diferenciál displej dobíjení dpf drl dsg dvb-t dvd dveře dx dálkové ovládání e85 ecu eds egr elektrická okna elektrika elektromobil elsa emise epc esp et ethanol facelift filtr filtr pevných částic fis fsi fólie g71 geometrie gps gufera h1 h4 h7 hagusy haldex hallův snímač halogen handsfree headup hid hodiny homelink hučení hydroměnič hydroštel imobilizér insp intercooler ipad iphone ipod iso isofix jak na to k-jetronic kabel kamera kapota karburátor kardan karoserie katalyzátor keyless klepání klepání motoru klika klima klimatizace klub klubová karta klínový řemen klíč kola kolísání otáček komfortni jednotka kompresor konektor kontrolka kontrolka airbagu kontrolka brzd kontrolka mazání kontrolka motoru kotouče kouřivost kufr kód rádia kůže lambda lambda sonda lampy leaving home led letní pneu lišty dveří ln2 log loketní opěrka low-range ložiska ložisko lpg manuál manžeta mapy maska maxidot mazání mlhovky mlžení oken mmi mmi 2g mmi 3g montáž motor mp3 mtm multifunkční volant multitronic měchy měrka oleje n75 napínací kladka napínák nastavení nastavení hodin navigace naviplus nefunguje nejede nestartuje netopí netáhne netěsnost nezávislé topení neřadí nouzový režim nádrž náklon světel náprava nárazník návod odblokování odtok odvzdušnění odvětrání klikové skříně oel okno olej olejnička olejová měrka olejová vana ostřikovač osvětlení osvětlení spz otáčkoměr otáčky palivoměr palivová soustava palivové čerpadlo palivový filtr palubní deska palubní pc parkovací brzda parkovací senzory parkovačky pd pdc phatnoise plnění plovák plynový pedál pneu podsvícení podtlak podvozek pojistka pojistky pojištění pomoc prosim popis pojistek posilovač počátek vstřiku pružiny pylový filtr párování klíče přehřívání přepínač světel přestavba převodovka příručka přístrojová deska q5 q7 quattro radar radio ramena redukce regulace turba relé blinkrů relé světel renovace disků repase repro rns rns-d rns-e rozvodový řemen rozvody rs4 rs6 ruční brzda rádiem řízené hodiny rádio s-line s-tronic s2 s3 s4 s6 s8 safe safe kód schéma sd karta sedačky senzor service servis servisní interval servo servo olej servotronic servořízení setrvačník seřízení hodin seřízení světel silentbloky sklo skryté menu snímač teploty spojka sportovní podvozek spotreba spotřeba spotřeba oleje spínací skříňka sraz ssp stahovačka start start-stop startování startér stk studený start stěrače střešní nosič střešní okno subwoofer svetla svody svolávací akce svítivost svíčky světla symboly symphony syčení sání síto sacího koše tachometr tažné zařízení tdi telefon tempomat teploměr teplota motoru teplotní snímač teplý start termostat teče servo olej tfsi tiptronic tlak tlak oleje tlak turba tlumiče topení torsen tpms trippling tt tuning turbo tuzing tv tuner táhlo tónování těsnění těsnění pod hlavou třetí brzdové světlo usb v8 vag vag chyby vačky vcds vdcs ventilakce ventilakcička ventilátor ventilátor chladiče vibrace vif vin vlnovec voda vodní pumpa volant volnoběh vrzání vstřik vstřikovací čerpadlo vstřikovače vstřiky vyhřívání vyhřívání okna vyhřívání sedaček vynechává vypíná vyčištění vzduchový filtr váha vzduchu víko ventilů výfuk výkon výměna vývěva větrák w12 wastegate webasto xcarlink xenon zadní stěrač zadní světla zamrzání zapalování zapojení zatékání zdvihátko ventilu zesilovač zimní pneu zpátečka zpětné zrcátko zrcátka zrcátka-ovládání zrcátka-stmívání zrcátka-vyhřívání zrcátko ztráta oleje zvýšení výkonu základní nastavení zámek dveří zámek kufru zásuvka únik oleje čelní sklo čep černý kouř čerpadlo čeština čidlo oleje čidlo teploty čidlo teploty oleje čištění čištění trysek řazení řemen řemenice řídící jednotka řízení řízení motoru škrtící klapka škube šíbr žhavení žhavící svíčky žárovky
