Tak jsem něco dohledal, třeba to někomu pomůže.
Reset
MMI*
Press up on Nav and Radio while pressing on the center wheel
__________________________________________________ _____________________
Security Codes
09 - Central Electrics: 20113
13 - Auto Distance Regulation: 20103
6D - Trunk Electric: 12345
57 - TV Tuner: 20103
CA - Sunroof: 20103
Enable Automatic Gear selection shown in DIS
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic
PDC* Front
[09 – Central Elect.] [Coding - 07]
Select Long Coding Helper
Select Bye 37
Check Bit 1
Long Coding Helper
Enable
ACC* default distance in
MMI* (might need security code)
[13 - Auto Dist. Reg][Adaptation - 10]
Select "Distance basic setting option" in dropdown
Select "On" from New value drop down
Save and reset
MMI*
Enable Laptimer shown in DIS
[17 – Instrument Cluster] [Coding – 07]
Write down coding as backup
Select byte 01
Enable bit 03
Increase time required to open trunk lid with remote key
[46 - Central Convenience][Adaptation - 10]
Scroll down and find channel "Time for opening rear lid with remote control"
Load Stored Value (should be 800 ms)
Enter new value in "ms". Example: 2000, Max: 5000
Double beep on opening (didn't work on my A4B9 after locking, waiting and unlocking, may need to wait longer)
Scroll down and find channel "sounder_settings-beeptime_opening_central_locking"
change from "no_beep" to "double_beep"
Not sure if this helps Canadian "non-AudiConnect" owner to enable the modem but might be worth a try
[5F - Information Electronics][Adaptation - 10]
Select "Vehicle configuration-LTE_module"
was "activated" in my US A4B9
On the topic of using an external SIM card for data, there is an adaptation channel in 5F called "Internal SIM card; use" with the default setting of "always".
Changing this to "automatic" extends the Data Connection Settings menu and allows entering an APN, username and password.
The MIB2 detected the required APN automatically based on the SIM card inserted just like older
MMI* head units.
Enable Sports Computer
Select Byte 10
Enable Bit 2
Disable Seatbelt Warning
Select Byte 0
Disable Bit 2
Enable Needle Sweep
Select Byte 1
Select Bit 0
Tailgate Opening Delay - Via Remote Key Fob
[46 - Central Convenience] [Adaptation - 10]
Lock/Unlock "Chirp"
[46 - Central Convenience] [Coding - 07]
Select Byte 4
Select Bit 6
Adaption Changes for "Chirps" when LOCKING the car:
Find channel "(2)-sounder_settings-beeptime_closing_central_locking"
Default Value is "single_beep"
If you want a single "chirp" when you lock the car, leave this setting as is.
If you want a double "chirp" when you lock the car, change the value to "double_beep"
Adaption Changes for number of "Indicator Flashes" when LOCKING the car:
Find channel "(3)-Turn Signal control-Confirmation flashing locking central locking; flashing cycles"
Default Value is "1"
If you want a single indicator "flash" when you lock the car, leave this setting as is.
If you want a double indiactor "flash" when you lock the car, change the value to "2"
Enable "Beep on Unlock"
Find channel "(1)-central_locking_system-beep_at_opening"
Default Value is "Off"
Change Value to "On"
Adaption Changes for "Chirps" when UN-LOCKING the car:
Find channel "(4)-sounder_settings-beeptime_opening_central_locking"
Default Value is "no_beep"
If you do NOT want a "chirp" of any sort when you UN-lock the car, leave this setting as is.
If you want a single "chirp" when you UN-lock the car, change the value to "single_beep"
If you want a double "chirp" when you UN-lock the car, change the value to "double_beep"
Adaption Changes for number of "Indicator Flashes" when UN-LOCKING the car:
Find channel "(3)-Turn Signal control-Confirmation flashing unlocking central locking; flashing cycles"
Default Value is "2"
If you want a double indicator "flash" when you UN-lock the car, leave this setting as is.
If you want a single indicator "flash" when you UN-lock the car, change the value to "1"
If you want a NO indicator "flash" when you UN-lock the car, change the value to "0"
DRL (Daytime Running Lights) On/Off Option in
MMI*
Select Byte 2
Select Bit 1
Enable ability to Rip CD's to
MMI* "Jukebox"
[5F - Information Electr] [Coding - 07]
Select Long coding helper
Select Byte 24
Select Bit 5
Adaption:
[5F - Information Electr] [Adaptaion - 10]
Module 5F - Information Electr
Scroll down and find channel "(2)-Copy multimedia data-Optical drive"
Load Stored Value (should be set to "Off")
Change to "On"
Audi Active Lane Assist - Steering Vibration Adjustment
[A5 - Front Sens. Driver Assist] [Adaptation - 10]
Scroll down and find channel "IDE05985-Directional stab. assist ; intensity; steering wheel vibration"
Load Stored Value (should be set to "Medium")
Change to either "Weak / Medium / Strong"
Lock When Driving
Module 46 - Central Convenience
Select Byte 35
DE-Select Bit 0
Disable "Low Wind Noise" Stop point on Sunroof
[CA - Sunroof] [Security Access]
[Adaption]
Find channel "IDE09451-MAS08937-Travel path-Sliding Position: intermed. pos."
Value should be "Active"
Change to "Not Active"
Parking Assist Camera - Turn Off Speed
[Adaptation - 10]
Scroll down and find channel "Switch off speed for park assist"
Load Stored Value (should be set to "10 Kph / 6 Mph")
Change to another value. Example "20" (which is about 12 Mph)
Seat Symmetry + Passenger Seat Control
**You need to do the SAME coding in Modules 06 and 36.**
[06 - Passenger Seat Module][Coding - 07]
Select Byte 2
Select Bit 5
Select Byte 6
Select Bit 1
[36 - Driver Seat Module][Coding - 07]
Select Byte 2
Select Bit 5
Select Byte 6
Select Bit 1
Enable & Pair a Second Phone via Bluetooth simultaneously
Scroll down till you find channel "IDE03471-ENG130247-Vehicle configuration-Support_second_phone" (name may be slightly shorter in ODBEleven)
Load Stored Value (Default will be "Not Active")
Change to "Active"
Enable Ability to lock car with Engine running
Select Byte 9
Select Bit 7
Disable rear wiper
[09 - Central Electrics] [Coding - 07]
Select Long Coding helper
Select Byte 12
Set Bit 6 to 0
Set Bit 7 to 1
Select Byte 12
Select rear_wiper
Set value to not_installed
De-Activation of
Start-Stop*
[19 - CAN Gateway] [Adaptation - 10]
Start-Stop* Voltage Limit>12V (New Value)
Enable
Coming Home*
Select welcome_light
Set value to 1
Activation of automatic opening of the car when approaching
The cart opens automatically when you are about 1-2m away.
automatic_opening
set to active
Disable side marker
Select Byte 6
Select Bit 4
[09 – Cent. Elect.] [Coding - 07]
Long Coding Helper
Select Byte 10
Uncheck Bit 3
Increase number of flashes when you nudge the stalk
Turn Signal Control => Freeway flashing cycles
Change value from 3 to 4 (1-5 possible)
Turn off range limiter for Comfort Window System
Coding->comfort_operation_range_limitation->not active
I haven't done mine, but apparently you can increase the range to lock / unlock.
Deactivate Key Lock Range
Coding->range_limitation_lock-> not active
Deactivate Key Opening Range
Coding->range_limitation_opening-> not active
Increase Steering Wheel Heater Temp
**should not go above 38C**
[16 - Steering Column Electronics]
Adaptation: steering wheel heater
Turns on low beam as well as high beam when you flash people with headlights off
Coding -> lowbeam_at_flash-> activate
Activate rear tail lights with DRL in Auto mode
Coding->signiturelight_config-> signaturelight_with_tailight
Enable Emergency braking
Select Byte 21
Set Bit 0 to 1
If
ACC* and Pre-sense
Set Bit 2 to 1
Set Bit 3 to 1
Select Byte 36
Set Bit 0 to 1
Set Bit 1 to 1 (for hazards to flash)
Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display
[17 - Instruments][09 - Central Electronics] [Adaptation - 10]
IDE01170-Visual display for park assist
Original Value - with OPS display
New Value - with OPS 360°
Change ventilated seat cooling fan speeds for each of the 3 setting
**Max increase is 10% over the default setting**
IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
Stored value 0 %
New Value - 10%
IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
Stored value 0 %
New Value - 10%
IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
Stored value 0 %
New Value - 10%
Change the Heated Seats temp in each stage
**5 DEGREES + OR - IS MAX VALUE**
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1
Stored value 0 °C
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 2
Stored value 0 °C
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 3
Stored value 0 °C
C to display SQ7 dials
In module 17 go into long coding
Then change vehicle variant to "derivative 2"
Apply changes
Come out of long coding
Choose reset
Then hard reset
MMI* startup screen to display SQ7 logo:
in module 5F long coding, change "byte_18_Screenings" from 27 to 28, reboot
MMI*
Automatic Parking Brake
[03 - Brakes] [Adaptation - 10]
Automatic Parking Brake -> Activited
