Celkem je zde 221 lidí (6 přihlášených)
Návštěvníků: 215
Uživatelů: 6
Celkem: 221
Registrace: 11.6. 2016
Příspěvků: 45 | Témat: 5
18.05 2018 19:50
ahoj,
dnes jsem nastartoval auto a vyskocila na me kontrola check engine. Zkousel jsem udelat diagnostiku a vypadlo mi toto - mohli byste mi prosím pomoct co s tím?
Děkuji
4 Faults Found:
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 275231 km
Time Indication: 0
Date: 2017.08.24
Time: 11:27:46
Freeze Frame:
RPM: 819 /min
Torque: 128.7 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 21.3 %
Temperature: 14.4°C
008598 - Oxygen (Lambda*) Sensor B1 S1
P2196 - 002 - Signal too High (Rich) - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 120
Reset counter: 255
Mileage: 279829 km
Time Indication: 0
Date: 2018.02.01
Time: 18:29:57
Freeze Frame:
RPM: 1218 /min
Torque: 0.0 Nm
Speed: 42.6 km/h
Duty Cycle: 1.0 %
Duty Cycle: 161.4 %
(no units): 1.0
(no units): 16.0
008324 - Exhaust Gas Temp Bank 1 Sensor 2
P2084 - 003 - Implausible Signal
Freeze Frame:
Fault Status: 01110011
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1050 /min
Temperature: 17.1°C
Voltage: 11.40 V
Temperature: 63.8°C
Temperature: 11.8°C
Temperature: 17.1°C
Temperature: 17.1°C
009259 - Exhaust Gas Temperature Sensor; B1 S3
P242B - 004 - Range/Performance
Freeze Frame:
Fault Status: 01110100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1050 /min
Temperature: 17.1°C
Voltage: 11.40 V
Temperature: 63.8°C
Temperature: 11.8°C
Temperature: 17.1°C
Temperature: 17.1°C
Příspěvků: 5147 | Témat: 33
18.05 2018 20:18
Vymenit teplotni cidla kyslikovou sondu a zhavic na 5 valci
18.05 2018 20:28
jsem zacatecnik, zvladnu to sam nebo je to slozitejsi? Nemeli by se ty zhavice vymenit naraz vsechny?
18.05 2018 20:29
myslim ze jsem je menil vsechny pred rokem nejde tam najit nejake datum kdy se s nima neco delalo? Jeste jsem se chtel zeptat, na kolik vyjde jedno to teplotni cidlo?
18.05 2018 20:49
jeste jsem se chtel zeptat, muze se s tim vubec jezdit? ceka me cesta 120 km, vydrzi to? neposere se neco?
Diky
18.05 2018 21:10
tak je lepší vyměnit všechny to je bez debat , ale nezjistíš jestli se snima něco dělalo
no pokud si zručný tak si to vyměníš sám
jezdit já si myslim že ne protože to přece musí padat do nouzáku ne ? a pokud máš DPF* což asi jo tak ho nezregeneruješ a odpálíš ho , a to vyskočili všechny najednou ? zkus kouknout jestli máš v pořádku kabel
18.05 2018 21:20
no auto jede normalne, akorat sviti kontrolka motoru. Myslis jako jestli vyskocili ty teplotni cidla vsechny najednou? Zkousel jsem to 2x a vyhodili to stejne chyby motoru. Mam ale uplne obycenjy vag a delam to pres nejaky vcds software. Stavalo se mi, ze kdyz bylo malo nafty, tak vyskocilo znecisteni filtru pevnych castic, muze to mit nejakou spojitost? Mechanik mi rikal cca pred pul rokem ze to proste takto dela.
18.05 2018 21:28
jj všechny naráz ,, to nevadí když to přečte tak to ukáže správně to vyskočí dobře když to auto nezpustí regenraci že má málo nafty nebo město a zanese se , ale já moc zkušeností s DPF* nemam , ale každopádně něco podobnýho jsem měnil na octavii a ty čidla vyšli na balík
18.05 2018 21:30
nestras, na kolik Te vysly ty cidla?
18.05 2018 21:58
to jedno teplotní vyšlo na 2500 bez dph snad přesně už nevim ta kyslíková vychazí cca stejně
18.05 2018 21:59
jeste jsem se chtel zeptat, tu diagnostiku jsem delal pri vyplem motoru, s klickem na ingnition, nema byt to auto uplne nastartovane?
18.05 2018 22:05
ne to si dělal správně
jako natočené může bejt ale to ukáže to samé
18.05 2018 22:12
myslis teda ze s tim radeji jezdit nemam, i kdyz to jede normlane jo?
18.05 2018 22:29
já bych stim nejel protože se nezpustí DPF* regenerace a zaplníš ho tak že to popravíš nadobro
18.05 2018 23:23
prosimte co to znamena, kdyz u te svicky je datum?
Reset counter: 255
Mileage: 275231 km
Time Indication: 0
Date: 2017.08.24
Time: 11:27:46
Diky
18.05 2018 23:33
To je ze chyba kdy tam naskocila v kolika km a jakeho datumu
19.05 2018 7:54
jeste jsem se chtel zeptat, neni divne ze odesly vsechny 3 veci naraz, ziju na vesnici, nemohl treba kuna prekousat kabely? Muzu to nejak zkontrolovat, je to nekde sespod nebo u motoru?
děkuji
20.05 2018 14:47
chtěl jsem se ještě zeptat, přejel jsem cca 20 km ke kamardovi co se mi na to podiva a frekvence chyb je porad 2 - znamena to ze ty sensory funguji? Jeste mi vyskocila kontrola DPF* ale ta pri jizde zhasla
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 275231 km
Time Indication: 0
Date: 2017.08.24
Time: 11:27:46
Freeze Frame:
RPM: 819 /min
Torque: 128.7 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 21.3 %
Temperature: 14.4°C
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 279829 km
Time Indication: 0
Date: 2018.02.01
Time: 18:29:57
Freeze Frame:
RPM: 1218 /min
Torque: 0.0 Nm
Speed: 42.6 km/h
Duty Cycle: 1.0 %
Duty Cycle: 161.4 %
(no units): 1.0
(no units): 16.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1050 /min
Temperature: 17.1°C
Voltage: 11.40 V
Temperature: 63.8°C
Temperature: 11.8°C
Temperature: 17.1°C
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1050 /min
Temperature: 17.1°C
Voltage: 11.40 V
Temperature: 63.8°C
Temperature: 11.8°C
Temperature: 17.1°C
Temperature: 17.1°C
Readiness: 1 1 0 0 0
27.05 2018 21:38
tak zkousel jsem vymenit svicky, jedna byla spatna. Po vymene vyskakuje porad ta Lambda*, myslite ze muze byt spatna?
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 283474 km
Time Indication: 0
Date: 2018.05.24
Time: 08:37:47
Freeze Frame:
RPM: 1050 /min
Temperature: 20.7°C
Voltage: 11.55 V
Temperature: 58.0°C
Temperature: 17.7°C
Temperature: 17.1°C
Temperature: 18.9°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 283474 km
Time Indication: 0
Date: 2018.05.24
Time: 08:37:47
Freeze Frame:
RPM: 1050 /min
Temperature: 20.7°C
Voltage: 11.55 V
Temperature: 58.0°C
Temperature: 17.7°C
Temperature: 17.1°C
Temperature: 18.9°C
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 283519 km
Time Indication: 0
Date: 2018.05.24
Time: 19:36:37
Freeze Frame:
RPM: 1260 /min
Torque: 0.0 Nm
Speed: 34.7 km/h
Duty Cycle: 1.0 %
Duty Cycle: 151.4 %
(no units): 1.0
(no units): 16.0
[vyřešeno] 1.2tdi 1.4i 1.6 1.6td 1.8 1.8t 1.9tdi 100 2.0fsi 2.0tdi 2.0tfsi 2.2t 2.5tdi 2.7t 2.7tdi 2.8 3.0tdi 3.3tdi 4.2 4.2tdi 4b 4f 80 8e 8l 8p a2 a3 a3 8p a4 a5 a6 a6 4f a7 a8 abs aditiva afs airbag ak certifikace ak eshop ak garáž ak karta ak kšiltovka ak servis ak svp ak vlajka ak znak alarm allegro allroad alternátor alu kola ami antiradar anténa asr audi audiklub audio autobaterie automat automaticka prevodovka autopotahy autorádio b2 b3 b4 b5 b6 b7 b8 baterie bezpečnostní šrouby bioethanol biturbo bixenon blacklist blikající kontrolky bliká žhavení blinkry blow off blow-off ventil bluetooth bmk bns bose bov brake fault brzdová kapalina brzdové světlo brzdy budíky bílý dým c3 c4 c5 c6 c7 cabrio canbus cd changer centrální zamykání changer chcípá chip chiptuning chladič chladící kapalina chladící systém chorus chrom chyba climatronic cng coming home comming home common-rail concert cukání cívka d1s d2 d2r d2s daylight demontáž denní svícení destičky dešťový senzor diagnostika diferenciál displej dobíjení dpf drl dsg dvb-t dvd dveře dx dálkové ovládání e85 ecu eds egr elektrická okna elektrika elektromobil elsa emise epc esp et ethanol facelift filtr filtr pevných částic fis fsi fólie g71 geometrie gps gufera h1 h4 h7 hagusy haldex hallův snímač halogen handsfree headup hid hodiny homelink hučení hydroměnič hydroštel imobilizér insp intercooler ipad iphone ipod iso isofix jak na to k-jetronic kabel kamera kapota karburátor kardan karoserie katalyzátor keyless klepání klepání motoru klika klima klimatizace klub klubová karta klínový řemen klíč kola kolísání otáček komfortni jednotka kompresor konektor kontrolka kontrolka airbagu kontrolka brzd kontrolka mazání kontrolka motoru kotouče kouřivost kufr kód rádia kůže lambda lambda sonda lampy leaving home led letní pneu lišty dveří ln2 log loketní opěrka low-range ložiska ložisko lpg manuál manžeta mapy maska maxidot mazání mlhovky mlžení oken mmi mmi 2g mmi 3g montáž motor mp3 mtm multifunkční volant multitronic měchy měrka oleje n75 napínací kladka napínák nastavení nastavení hodin navigace naviplus nefunguje nejede nestartuje netopí netáhne netěsnost nezávislé topení neřadí nouzový režim nádrž náklon světel náprava nárazník návod odblokování odtok odvzdušnění odvětrání klikové skříně oel okno olej olejnička olejová měrka olejová vana ostřikovač osvětlení osvětlení spz otáčkoměr otáčky palivoměr palivová soustava palivové čerpadlo palivový filtr palubní deska palubní pc parkovací brzda parkovací senzory parkovačky pd pdc phatnoise plnění plovák plynový pedál pneu podsvícení podtlak podvozek pojistka pojistky pojištění pomoc prosim popis pojistek posilovač počátek vstřiku pružiny pylový filtr párování klíče přehřívání přepínač světel přestavba převodovka příručka přístrojová deska q5 q7 quattro radar radio ramena redukce regulace turba relé blinkrů relé světel renovace disků repase repro rns rns-d rns-e rozvodový řemen rozvody rs4 rs6 ruční brzda rádiem řízené hodiny rádio s-line s-tronic s2 s3 s4 s6 s8 safe safe kód schéma sd karta sedačky senzor service servis servisní interval servo servo olej servotronic servořízení setrvačník seřízení hodin seřízení světel silentbloky sklo skryté menu snímač teploty spojka sportovní podvozek spotreba spotřeba spotřeba oleje spínací skříňka sraz ssp stahovačka start start-stop startování startér stk studený start stěrače střešní nosič střešní okno subwoofer svetla svody svolávací akce svítivost svíčky světla symboly symphony syčení sání síto sacího koše tachometr tažné zařízení tdi telefon tempomat teploměr teplota motoru teplotní snímač teplý start termostat teče servo olej tfsi tiptronic tlak tlak oleje tlak turba tlumiče topení torsen tpms trippling tt tuning turbo tuzing tv tuner táhlo tónování těsnění těsnění pod hlavou třetí brzdové světlo usb v8 vag vag chyby vačky vcds vdcs ventilakce ventilakcička ventilátor ventilátor chladiče vibrace vif vin vlnovec voda vodní pumpa volant volnoběh vrzání vstřik vstřikovací čerpadlo vstřikovače vstřiky vyhřívání vyhřívání okna vyhřívání sedaček vynechává vypíná vyčištění vzduchový filtr váha vzduchu víko ventilů výfuk výkon výměna vývěva větrák w12 wastegate webasto xcarlink xenon zadní stěrač zadní světla zamrzání zapalování zapojení zatékání zdvihátko ventilu zesilovač zimní pneu zpátečka zpětné zrcátko zrcátka zrcátka-ovládání zrcátka-stmívání zrcátka-vyhřívání zrcátko ztráta oleje zvýšení výkonu základní nastavení zámek dveří zámek kufru zásuvka únik oleje čelní sklo čep černý kouř čerpadlo čeština čidlo oleje čidlo teploty čidlo teploty oleje čištění čištění trysek řazení řemen řemenice řídící jednotka řízení řízení motoru škrtící klapka škube šíbr žhavení žhavící svíčky žárovky
