Tak cca po roce opet vyskocila ta sama chyba a v logu je neco u BMM, odchazi baterka nebo relatko starteru?
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 28 34 36 3B 3C 42
44 46 47 52 53 55 56 5F 62 6D 72 82 85 8B 8E 8F 90 A9 C0
VIN*: WAUZZZ4G6DN003760 Mileage: 215857km-134127miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-
ABS* Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-
ACC*/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-
AWD* -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 E HW: 4G0 907 589
Component: 3.0BTD EDC17 H21 0002
Revision: 57H21---
Coding: 122A401A056601020000
Shop #: WSC 33097 001 1048576
ASAM Dataset: EV_ECM30BTD0114G0907589E 001002
ROD: EV_ECM30BTD0114G0907589E.rod
VCID: 36634CBE898657F24A-8062
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1008
Revision: --H16---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_AU48.rod
VCID: 6ED3A4DEB1562F3242-803A
Address 03:
ABS* Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component:
ESP* PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 49B7C70192EDE380DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 387F42868392A18258-806C
Address 05:
ACC*/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CP HW: 4H0 907 064 CP
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 05892F46000000000000
VCID: 79F98782F018788AE7-802C
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0070
Serial number: 16051200040970
Coding: 361200783D
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS.rod
VCID: 62CBC0EE758E9B52D6-8036
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001304704
Coding: 0200201150B49FE2E98100C7A0001908CF9CC7082E080201800008406101
VCID: 6ED3A4DEB9562F3242-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120324 H35 0080
Serial number: 120423152747
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20263531
Coding: 0200FD
Subsystem 3 - Part No SW: 4G0 941 531 G HW: 4G0 941 531 G
Component: E1 - LDS H07 0044
Serial number: 07 05 2012 00000224
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103529000001240228
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: BEB8C926000000000001
Address 10: Park/Steer Assist (J791) Labels: 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 AF HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0050
Revision: -------- Serial number: 56261212902640
Coding: 982B08
ASAM Dataset: EV_EPHVA2CAU57X0000 002011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 76E38CBEC90617F28A-8022
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Serial number: 00000000000000
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 285F92C653323102C8-807C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG008F7AZ
Coding: 30323436313330303335554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
Crash sensor for side
Airbag*: driver side:
Serial number: 3575HRB404T1BBH4F1JJ
Airbag*: front passenger side:
Serial number: 3585HRB405V1C4LI49ER
Airbag*: rear: driver side:
Serial number: 3515JRB4063184CO094H
Airbag*: rear: passenger side:
Serial number: 3525JRB405D18E5E89F$
Crash sensor for front
Serial number: 3554VRB40064UD62TH7W
Serial number: 3564VRB400A4UD62DOJ/
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LE4000TZ
Coding: 0000FD
VCID: 377D41BA868CAEFA51-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Serial number: 09 04 2012 B0154168
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 932 M HW: 4G8 920 932 M
Component: TDieRdwAcc H79 0515
Revision: 28460207 Serial number: 658080512596011
Coding: 138F11009F550008000000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 39794782B898B88AA7-806C
Address 18: Aux. Heat (J364) Labels: 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20120806131723
Coding: 553F01
Shop #: WSC 79782 146 97083
VCID: 244786F6271AD562E4-8070
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000517609
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
ROD: EV_GatewPkoUDS_AU57.rod
VCID: 70EFBAA6AB6239C250-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790227394
Voltage stabilizer:
2 Faults Found:
12290 - Quiescent Current
U1406 00 [008] - Too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 3
Reset counter: 10
Mileage: 215855 km
Date: 2018.08.23
Time: 17:40:16
Voltage terminal 30: 12.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 37 °C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 215855 km
Date: 2018.08.23
Time: 23:47:16
Voltage terminal 30: 12.4 V
Control Module temperature: 30 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 22:
AWD* (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 000105120001012
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 275D91FA5E2C3E7AC1-8072
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0070
Serial number: 17051200041311
Coding: 21
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS.rod
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E5364DE71D66F3202-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000029430668
Coding: 00581B0000006001000001010101102030303232203232
VCID: 77FD81BAC60C6EFA91-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 C HW: 4G0 907 637 C
Component: SARA 6D red H02 0009
Revision: -------- Serial number: EJ1BPA3E00D36X0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0000102
VCID: 306F7AA6A3E279C210-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F10.05.1200H010003CF24089ÿ
Subsystem 4 - Serial number: F24089ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0506
Coding: 011F1E015E00628002080013
VCID: 45813B72CC60CC6AD3-8010
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0003555855
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_AU57.rod
VCID: 326B70AE65EE4BD266-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0175520068
Coding: 01000E2020B93095832009800E03040F0000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Serial number: WOO16019371
Coding: 901F00
Subsystem 2 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00001119106
Coding: 010000
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Serial number: WOO1601932$
Coding: 801F00
Subsystem 4 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84253789
1 Fault Found:
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 215849 km
Time Indication: 0
Date: 2018.08.23
Time: 14:58:44
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000052443
Coding: 030000
VCID: 1D31B3120470E4AAAB-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0506
Coding: 011F1E015E00628002080002
VCID: 44872676C75AF562C4-8010
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component:
EPB*-4 H03 0013
Revision: -------- Serial number: 00000000301148
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU57.rod
VCID: 2B556DCA42C41A1A25-807E
Address 55: Headlight Range (J431) Labels: 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 120511-0004-050
Coding: 11226F33F91AEB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
Left Headlamp Power Output Stage:
H02 0009
Coding: 1D0000
Right Headlamp Power Output Stage:
H02 0009
Coding: 1D0000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227EX0C7580180
Coding: 010003010000000001
VCID: 21498FE23808C04A8F-8074
1 Fault Found:
01609 - Cooling Fan in Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 2
Reset counter: 10
Mileage: 215852 km
Time Indication: 0
Date: 2018.08.23
Time: 15:15:20
Freeze Frame:
Voltage: 14.40 V
RPM: 30 /min
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 H HW: 4G0 035 666 H
Component: H-BN-EU H49 0526
Revision: -------- Serial number: 189DZ0C7503244
Coding: 050100010003FFED7DB0CF3E00000003E80101020000000000
VCID: 2D5163D274D0142A3B-8078
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94018J6I
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LEB000MD
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0506
Coding: 010F1C004000628002080002
VCID: 479D317AF66CDE7A21-8012
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 126200930
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
VCID: 346776B69FFA45E274-8060
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0506
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 G HW: 4G0 919 604 G
Component: HeadUpDisplay 005 0106
Revision: 00000000 Serial number: 00000000000000
Coding: C70000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 2F6D79DA76DC663A09-807A
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: EE060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 26439CFE59262772FA-8072
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051405127
Coding: 04C0BB1A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31697FA260E870CA1F-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120419201208
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 120419202015
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 244786F62F1AD562E4-8070
End-------------------------(Elapsed Time: 06:58)--------------------------
